Hi,
I have a 52 plate Hyundai Getz 1.3 with intermittent starting issues.
It started with the car cranking but not starting one morning, I was able to get it to start by bump starting it and then it started fine the next morning.
However later that evening it refused to start again with the same issue.
Any advice on what it could be?
Load test the battery......Grounds....codes?
Keep an eye on your immobilizer warning light (symbol of a car with a key inside).
It should come on along with all the other ignition warning lights. If it's not on when you switch the ignition on the engine will crank but never fire up.
How old is the battery? Some batteries will give out on cold morning if old.
check battery (flat is obvious). check charge with alternator. check fuel pump (you can hear it pump when you put can in ON). Solder immobilizer antenna coil wires. make sure correct fuel. make sure spark plugs are in and ignition coil isnt broken. in that order. car will start 100%
