my back left window doesn’t roll down or up most of the time and master controls don’t work for the right side of the car as well but they still work fine with the normal controls.
I haven’t try to fix anything so please help.
You'll need to do some work. Do you have a dvom?
Or you can try throwing parts (switches) at it.
2007 Honda CRV
Master control does work for right side??
And left rear is intermittent??
Door switches operates windows okay??
Sounds like you already know the master switch needs to be replaced.
First thing to do is to remove door panel and inspect the master switch, the wiring and connector.
The right side master controls don’t work for the right side but the normals switches do. It’s just the left rear window the doesn’t work at all most of the time. Sometimes I can roll it down and sometimes I can’t.
2007 Honda CRV
Does all the normal switches work including the left rear?
The master switch does not work for the right side.
So it is a good indicator the master switch needs to be replaced.
If left rear window normal switch does not work
Then the window needs to be investigated
Check to see if the window moves up and down freely?
Check to see if motor operates?
ok I’ll get back to you this weekend when I have time to check
