Hello all, My 2012 Equus Signature Air conditioning has become intermittent. While driving it will suddenly stop cooling the air. The fan continues but no AC. Also on three occasions the AC failed to cool when the engine was started. Again, the fan moved the air but no cooling. Basically, the AC either works okay or it does not work at all. This has been happening for about two weeks. Any ideas? Thanks.
Get the pressures checked and if it is the clutch style compressor make sure the clutch pulls in when the AC is commanded on. Sometimes the clutch gap gets too wide and when hot the clutch coil cannot pull in the clutch.
Thank you both for your help. I will now know what to ask about when I take my car in for repair.
