Just bought a Venue in the late afternoon and drove it home. When I arrived it was dark. Getting out of the car the interior lights did not go on automatically when I opened the door. How do you fix this? The lights work if I manually press their switch to the on position but then I have to manually turn them off. This can't be right. Will definitely call the dealer but maybe somebody else has had this problem?
Mine has a three-position rocker switch. If you push it all the way to one side, it is ON. All the way to the other side, it is OFF. But if you keep it in the middle, it is "on when doors open." You have to be careful to get the switch between the two extremes.
Mine is an SE, and this light is over the back seats. I don't know why I don't have a light between the visors where it would do the most good. There is a depression in the ceiling as if a light is intended to go there, but it isn't there.
Usually the lights have a switch, with three adjustments.
First - Turn off
Second - Turn on when doors open
Third - Turn on
May be try adjusting this
