2011 veracruz
Cant figure this one out. The interior map lights and second row dome and third row dome are supposed to come on when the door opens or when you unlock the door with remote. All lights and courtesy lights come on when this happens except the first row of lighting where the manual says the map lights come on. They work manually but not with the door or remote. I went through the manual and cant find anything. I thought I read where you can change this so they don't come on but I cant find it.
Thanks
No luck
The light is just a push button. The other dome lights have the door/room button. The map buttons are just a push on/ push off
Map-lights should operate like you stated in the first post... they are powered from the same power source and BCM (body control module) output. Unless you have replaced the lamps with LEDs???? then you most likely have a defective light assembly or a loose electrical connection.
Connection
Could be but it would have to be in the module. The light works when you push the button.
Had the map light problem on my 2010 VeraCruz. Tech discovered an internal short in the lamp assy and it was replaced under warranty. Retail price was listed as $180 so I'm glad of that. Apparently the electronics in there that control the " dimming down" was the culprit.
