Hello everyone,
my name is Mark and i'm new here. I'm from the Netherlands and i drive a 2008 Santa Fe GLS 2.7.
I wonder if anyone of you changed their instrument cluster with one of the facelift model (2010-2012)? I think they look nicer.
If i would change the cluster, is the mileage still the same or does it show the mileage of the new cluster?
Thank you in advance.
Mark
Hi Mark.
The mileage is stored in on a chip inside the instrument cluster, so the replacement cluster will display whatever mileage is stored within it, not what was stored in your original one.
Thanks for the info.
I made one cluster out of two. I used my own cluster for the electronics, and the needle plate from the new one. Works perfect. Only thing i had to do was relocate the led for high beams, it's in a different spot at the cluster from 2011.
Mark
