Noted a tapping noise coming from the RR @ highway speeds, upon inspection. I noticed the inner wheel well trim toward the rear being loose & it is aligned with a stud. On the Drivers side there appears to be a plastic wing nut on but was coming loose.
Common problem?
I also noted I am missing at least 3 rubber overslam bumpers on various areas of the doors too.
Getting ready to spray (hopefully) the entire lower body with oil so am becoming attentive to missing parts.
Discussion Starter #2
Got to "look at it" in daylight, not a wing nut some sort of hex nut with a built in fender, not even sure if this is a nut or a clip.... proprietary Hyundai clip or fastener?
Anyways they fall off the car, like the overslam bumpers.
Discussion Starter #5 (Edited)
Missing one, the other loose, these are tucked up behind the well, hard to see, for future reference, & if you hear something loose...
Hyundai OEM# 84145-26000
It's more like a push on nut, not a wing nut, I'm not sure they are even threaded.
441256
Things I own tend to "fall apart", or seize up.
Probably have to go to the dealer for this as I don't purchase online.... or live with the rattle for a while. Anyways I'm glad it's nothing major.
