I have a problem with my offside indicator, it has started to flash double speed.
The strange thing is all the bulbs are working on both lights, the problem is only on the offside indicator, the nearside works fine and when I put on hazards they both work fine.
Discussion Starter #2
UDPDATE: after fiddling around today I have found a solution (sort of) I thought I would post it here just in case anyone else had this issue.
The problem is caused by the trailer hitch, there is some sort of problem with it, I have now disconnected this wiring loop and everything now works fine.
Hi Matt, sorry nobody was able to help with the problem, but thanks for sharing the fix.
