Hi,
I'm converting a i800 to a camper. I want to remove the rear AC/Heating unit, but keep the cabin AC/heating in tact. Would anyone be able to advise me on this ?
444712
Your heat can be bypassed but the AC will need to be retrofitted as the system is setup for both.
So can I just remove that whole unit ? I'll loose AC but heating will be ok. I live in a cold country so I can do without AC but not heat.
I bypassed rear heat in a Kia sedona by cutting the pipes behind the engine bay and using a piece of hose to loop the feed. This was after the rear pipes split all over the place. Was fine. Aircon wise, I was told you could do the same using the same principle after the rear aircon unit failed, but I replaced the van first. Info was from an independent aircon company. Also the iload has the same system but no rear aircon.
