I have an opportunity to buy i45 wheels for my car, will they fit straight on? The guy says they are 16 x 6.5 PCD 114.3 Bore 67.1 but I'm not sure if the offset is compatible?
I haven't found any aftermarket ones I like and these are pretty cheap and I could use my tyres so it would be great if they did :)
The bolt pattern is the same 114.3. As for the offset l could not tell you as every rim is different and will need a different adapter.
Someone else can tell you on that part.
