At the start of 2019 my 2012 i40 Tourer blew the 15A Centre Console / Media fuse. I replaced this and all was well, however during the year the fuse would blow every now and again, until it now always blows. Initially I could turn the ignition between off and position 1 and the media unit would happily turn on and off, but each time the engine is started the fuse would blow. Now the fuse trips if the ignition is moved from position 1 to off or when starting the engine.
My first thought was a broken or bare wire, but after having a look at the back of the media unit during lockdown there is nothing obvious….unless it’s in one of the looms behind the dash.
Post lockdown I booked the car into my local Hyundai garage for some investigation and one thing that came back was the “battery wasn’t holding charge” and should be replaced. According to Hyundai, this can cause the media fuse to blow (never heard of that before?). The battery has now been replaced, however it hasn’t fixed the fuse issue.
Has anyone else had a similar problem?
Also any other ideas of what I can try to resolve the problem.
