I own a i30 since last month. Last few days, as the temperatures over night fall below 0 degrees Celsius, I'm experiencing problems with radio resseting when I power on the car in the morning. When I put the key on the first position (electricity only), the radio turns on, and everything is still ok, then I start the engine (which takes about 3 seconds, probably because the engine is still cold, in this moment the radio goes off, which I think is ok). After the engine is started, the radio is turned on again, but all the memory settings are gone. What could be the problem?
Thanks.
Nikola
Try switching off the lights the night before, it could be the extra drain on the battery as lights can come on automatically with the engine. But still a fault.
