I tried ignition on my i20 today, the airbag warning light came on and nothing else (no other lights). Car didn't start. Just checked the car myself this evening, and it's now totally dead - low interior light, but completely lifeless otherwise, when I tried turning the ignition.
Anyone know what this is? Dead battery? Airbag issue? Alternator issue? Something else?
Thanks!!
It sounds like there is no power being supplied to your instrument cluster, hence no warning lights when you switch the ignition on.
The first thing I would do is replace the CLUSTER fuse, located on the dashboard fusebox. See if that at least gets your warning lights back.
The CLUSTER fuse is part of the charging system. It's possible that the alternator hasn't been working if that fuse has been blown, so the battery might now be flat too.
446161
I found the fix.
The battery was low due to the fact that my brother left lights on overnight which drained the battery.
Recharging the battery helped.
Thanks for the help!
Glad it was a simple fix (y)
