Can you explain a bit?
How is this done? What does it cost? Any disadvantages?
I'm interested.
Values are changed in the ECU to change the behavior of the turbo and the engine, much like they do for the 1.0 100ps and 1.0 120ps, same engine, different maps.
It was done by programming the chip directly, the port has too many protections. It cost me around £360.
You have to do it properly to ensure values are not set that could damage the engine, if you drive the car hard after getting this done you will see accelerated ware of parts from brakes to tyres to the engine.
I do now have the same torque figure as the 1.4 turbo in the I30 however now :D
Hey, do you know if 100Hp is the same engine as 120HP ? i crash my i20 and i need a new engine.. and i found a new engine but is 120HP.. it will fit?
