Hi,
My 2010 Hyundai i10 - petrol - started smoking in the car, stopped and everything looked OK under the bonnet? Started can but now the windows, heater fan, heated seats, air con and wipers all don't work? Checked fuses and all fine. Engine also refused to start later, turned key but no power but started after a couple of times.
Had diagnostic on OBD port and showed P1107 (air sensor?) plus C2100 which not sure what this is.
Is the problem the Body Control module or something else. Just guessing as I cant even find the BCM !!
All help gratefully received.
regards
regards
