1 - 11 of 11 Posts
I've seen many kits but to date, they what I've found only go up to the 2016 SF. Does anyone know if the 2017 and 2016 share the same platform? I should be ok with purchasing the 2016 kit, right?
Thanks for any feedback!
First, I do not know the answer to your question. Second, there was definitely a change from 2016 to 2017 including an updated engine. There is no reason to expect that there weren't changes to the suspension as well.
That being said, the MEVOTECH CMS901214&15 (Control Arm w/ Ball Joint found on RockAuto.com) fits on the 2016 and 2017 model. So, at least that is the same. Did you call anywhere?
Why? What is the appeal? Not criticizing, just curious.
I actually like the SF lowered a bit, i was actually thinking of doing it for a while but i am so done with the tuning thing specially out here with snow.. I also wanted to get this kit and basically do a replica of this set up
Love the wheels too i cant find them anywhere...
I actually like the SF lowered a bit, i was actually thinking of doing it for a while but i am so done with the tuning thing specially out here with snow.. I also wanted to get this kit and basically do a replica of this set up.
That does look good. I would like to do that but using the stock SFS wheels that came with it. Those wheels are one of the reasons I like the '18 Sport model. That looks like almost a 2" drop, any idea?
I see it now; good luck!
not sure but i can tell you that these are 20" wheels
They're definitely available in the Korean market. all you need to do is find a distributor that will send you one to the states.
1 - 11 of 11 Posts
