My car when I pass more than 50 Mph, my transmission goes down to 3rd gear from 4th gear and I put my OBD scanner and I don't remember exactly the code I think it is P0721 but I'm not sure, but I remember that the scanner seems to me the output speed sensor OSS was damaged, this is the sensor that I bought and changed 42621-39052, and it gets stuck between the 2nd and 3rd engine and I need to turn it off so it will recognize 1st and 4th again.
When I delete the code with the scanner everything is fine but when I exceed 50mph the problems start.
Thank you for your answers.
It's going into fail safe with manual 2nd and 3rd available I assume. Yes when you cycle it clears the code and the TCU operates the solenoids normally again but when that code triggers it's going back to failsafe
can we get more info on year, motor fitted and your location? I just want to see which box is fitted. Interesting it's above 80kph when it triggers. I've had sensors fail on a A4CF2 box , i30 but it shut the box down as soon as it shifted. Left me with 2/3 using the shifter
You may have to investigate the VSS. looks like at higher speeds above 18MPH it does a comparison between the VSS and the OSS. a significant difference will also trigger the same code. You may want to confirm what the exact code is, I see P0720 for OSS cct .
The VSS is likely on the differential housing.
Also check wiring is good, no corrosion etc
That's all I can think of but I'm a little puzzled it does not mention the VSS in the likely cause list for P0720
Thank you very much for your answers, as I see the engine code is G4GC, 2000 C, I imported this car from the United States to Guatemala, the code is P0721 and it happens as you say when I remove the battery the code disappears and returns only with the condition that it goes over 80 kph, I have driven below that speed for 15 days and the Check Engine light is not turn on and the car works perfectly.
