1 - 17 of 17 Posts
I'm looking to get a spare key made for my 2000 Hyundai Accent GS, but it seems like all the places I try can not do it. I tried Ace Hardware, Walmart, and a few local shops and none of them can do it for me. And suggestion on where else I could go?
QUOTE (DonGiovanni023 @ May 20 2010, 03:23 PM) index.php?act=findpost&pid=324731
If you got a key tag that has a code on it when you bought your car, you can go to a Hyundai dealership and see if they can make a spare key for you. I know that they gave me one when I bought mine new for if I ever needed get another key made.
QUOTE (02accentgrl @ May 20 2010, 03:31 PM) index.php?act=findpost&pid=324734
The key code is only a neccesity if you don't have a key to copy. The dealer will also copy a key for you, as long as you can show proof of ownership.
I've had keys made at Things Remembered, they used a Cole HY6 blank.
Go to the parts counter at your local Hyundai franchise...
Have the VIN, and proper documentation that you are registered owner of vehicle (thats what we require at our place),, DMV registration/title to car, driver license, and part Manager will get on his terminal and run VIN for key code..
If dealer has code cutting ability, they will cut... we do not, so we have lock shop about 1 minute up the street who we use for lock repair and key cutting.
QUOTE (rsquared @ May 20 2010, 09:30 PM) index.php?act=findpost&pid=324886
not all Things Remembered locations make keys.....so it depends on the location.
QUOTE (rsquared @ May 20 2010, 10:36 PM) index.php?act=findpost&pid=324908
Unless I'm mistaken...they have a key and just need a copy. Any locksmith or place that cuts keys should be able to make one. If they have the right blank.
not ANY place will work, because they have different lengths of keys. Thats why I mentioned a Hyundai dealership because you're likely to get a key that works, and is exactly like the original...and going to hyundai, you might can get one with a rubber end on it like the original
QUOTE (02accentgrl @ May 28 2010, 05:28 PM) index.php?act=findpost&pid=327441
YES, any place than has the right blank can cut a working key(most guarantee them to work). If you have to have the rubber end with the "H" on it you have to go to the dealer, if that's not that big of a deal...a locksmith can make one for a fraction of the dealer price.
You need to have a new key (unworn) to duplicate,,, as using a well worn key for the model; and duping it will produce a dupe of the worn key... Now you just bought a duplicate of your existing worn :thumbsup:
QUOTE (sbr711 @ May 31 2010, 09:25 PM) index.php?act=findpost&pid=328273
Sometimes you need a "well worn" key to work in a "well worn" lock. If the shoe fits...wear it. lol.
I learned the hard way by locking my key in the car. A mobile locksmith was able to make a spare key on site after retrieving the other one. HTH!
I found it hard to get keys for my 02 accent copied correctly. walmart=fail, lowes=fail Finally ended up using True value key works like a charm. If its a blank you need they are readily available on ebay. search by make & year.
Hyundai factory key blank can be ordered at any Hyundai dealer, and be there in couple days depending on how far away from region PDC.. no cost for shipping.
1 - 17 of 17 Posts
