1 - 11 of 11 Posts
Hi there. My blower direction isn't working when I select mode on the control panel. I replaced the actuator (air flap actuator) but it is only moving when I change the temp on the display???
Also... If I manually operate the actuator control, it doesn't seem to do anything.
I'm a little confused at this point. Has anyone got any suggestions?
If the actuator only moves when you change the temperature would that not maybe be the temperature control actuator rather than the air direction one?
Hmmmm, I think you could be right. Do you know ehere the directional actuator is located?, it seems like I have replaced the wrong one.
I think it's on the driver's side of the heater box.
The way to tell the two apart is to count the number of wires on the harness connector. The temp control actuator has 5 wires and the direction one has 7.
Thank you so much, that's really helpfull to know. I'll have a search for it tomorrow.
I found the directional actuator and the peg on the large operation wheel had popped out of its slider so it is now working. However, the heater flap actuator isn't working and the one that I purchased isn't the correct one therefore I am going to return it. Does anyone know where I can source a replacement?
You could probably source the direction actuator (actually called the mode actuator if your searching for it online) from the same place as you got the temperature control actuator. Failing that there is always ebay....or your Hyundai $tealer.
I think the Hyundai part number for the mode actuator is : 97010H1733 (assuming LHD). But obviously confirm that for yourself before purchase.
Discussion Starter #9
Thanks for you replys they are really helpful and I very much appreciate them. My model is a RHD (I'm from the UK) and my actuator doesn't quite look like 97010H1733 (as you say, that one is for LHD)
1 - 11 of 11 Posts
