2012,, all kind of fun here
- Version 2 software update if not done in the past
- Couple additional update that come along later after the Vers 2 update
- Verify HSG Resolver Calibration
- Verify E/C calibration
- Verify inverter coolant properly filled in bottle, need run coolant pump via GDS to fill if excess low coolant to bleed
- Seeing transmission Electric Oil Pump break the center pump cog off the electric motor shaft, done maybe 4 in last yr now,, electric motor shaft spin and not drive the pump gear
- Had a transmission replacement a few month back
- Done a bunch of Power Relay Assembly within the Hybrid Battery module
