1 - 8 of 8 Posts
Pls help , in England right now it’s really hot & my air con has never worked, the ac button lights up but it just blows hot air, any help would be great , I went to have the gas done but they said that wasn’t the problem, many thanks guys from a sweaty Brit who needs help ?
Gas done? Do you mean refrigerant R134?
Does the compressor engage? Need some info. No silver bullets here.
Not very savvy with cars at all so sorry to sound thick, took car to a garage to get air con re gassed but he said it’s fine no leaks there’s a fault with it, don’t know where to start, button lights up so fuse must be ok? Just don’t want to get fleeced by a garage
Sounds like the garage you had check the 'gas' is OK. Make sure the clutch is connected. It's the wires at the front of the compressor.
Where would I find this pls?
Thanks in advance ??
If you don't know where the compressor is you're going to need to take it to a shop. I'd take it to the place that checked your 'gas'.
1 - 8 of 8 Posts
