Hello.
I bought a speedo sensor 3 pin plug replacement for my Hyundai iX35. The wiring on the 3 pin plug is black/yellow, blue/red and red/white. On the other hand, three wires leading to the computer box which I must connect to the plug are black, brown and white. How do I match the colors which are different ?
You shouldn't need to match any wires. The correct speed sensor will just plug into the car's harness.
My car uses a speedo driven gear and a plug with wires connected to the computer box must be plugged on to the gear.
Most Hyundai cars use a gear driven speed sensor. But when you replace the sensor you unplug the old one and the new one just plugs in where the old one was unplugged. You normally wouldn't need to match up any wires.
What's this computer box your talking about? Is the car used as a taxi or used for some other commercial purpose that might require monitoring how far/fast the car is being driven? Can you post some pictures that might help us understand what the problem is?
