1 - 18 of 18 Posts
Hyundai-Forums.com Vendor
Hyundai HID Conversion Kits
Diode Dynamics is pleased to announce the new Premium Diode Dynamics HID Conversion Kit. This kit has been carefully designed from the ground up to be the highest-quality HID kit available on the market, without exception.
Ballast: The ballasts are the most important component of an HID kit, as they provide the power. After years of providing midrange and high-quality ballasts for vehicles of all makes and models, Diode Dynamics learned what was important in making a good ballast, and applied it when designing these.
Controller Chip. Most digital (DSP) ballasts on the market still use generic chips, which are cheap, and work pretty well. However, when you need maximum quality, you need a new computer chip designed for one purpose. This is known as an Application-Specific Integrated Circuit (ASIC). These ballasts use brand new DSP ASIC chips for maximum efficiency and brightness, fast warmup time, and extremely stable operation.
CAN-BUS. Some vehicles have systems which sense the power consumption. Since HIDs use less power than factory halogen bulbs, this can cause issues. You can resolve this by adding capacitors, known as warning cancellers, or some ballasts come with them built-in. However, sometimes that's still not enough to trick the vehicle! To fix it, this ballast has not one, but two CAN-BUS modules, which provide capacitance and resistance to the circuit to defeat even the most troublesome modern CANBUS systems. Even if your vehicle does not use a CAN-BUS system, these modules will provide extra power smoothing for reliable operation. Simply put, this ballast will work on any vehicle, the first time you plug it in. With this kit, you don't need to worry about capacitors, warning cancellers, or resistors.
Igniter and Startup. You may have heard of ignition issues with other ballasts, caused by an igniter that is too small to withstand cold temperatures. No reason to worry with these ballasts- the oversized 24kV external igniter means that you will never have an ignition issue, even in the coldest temperatures. Additionally, the ASIC chip in these ballasts means that you only need 4 amps at nominal voltage to start up. These ballasts consume less power than any other on the market, meaning 100% reliable and fast startups, every time.
Shielding. Ever noticed a little black plastic thing clipped onto your laptop charger cord? That's a ferrite bead, which is used to suppress high-frequency signals, which can create radio interference. All ballasts generate these signals, and most just have protection in the ballast. We've also included ferrite beads on the wire, to suppress them.
LED Indicator. Convenience is key, especially during installation. To make things easy, we've added an indicator LED on the input wire, so you know that the ballast is getting power.
Case. These ballasts are the smallest you will find, about the size of a pack of playing cards. The case is fully potted, or filled with epoxy, which makes them fully waterproof and shockproof. Most ballasts on the market are filled to some degree, but these are completely filled to the top, sparing no expense to ensure longevity.
Bulbs:
The bulbs included with Diode Dynamics kits are CNLight bulbs. CNLight is the top manufacturer of aftermarket bulbs in the world, providing the best quality available. You might see other high-quality kits on the market which also use CNLight bulbs. They provide superior life, brightness, and color attenuation when compared to generic HID bulbs, like those found in most cheaper kits on the market. The one-piece base design prevents any issues with separation over time, making the entire bulb extremely reliable.
The CNLight bulb temperatures are rated accurately in Kelvin temperature at 35W, and have an industry-standard 3000 hours of estimated bulb life, which should outlast your vehicle. Please be aware that most HID bulbs are rated inaccurately from other manufacturers. 8000K is not dark blue, and 6000K is not pure white! We provide accurately-measured colors. 3000K is our lowest temperature, and has a pure yellow output, which is great for use in fog lights. 4300K is a pure white output, as seen on many factory HIDs. It will not have any blue tint to its color, and might appear slightly warm. 6000K is our most popular color, which produces an ice white color. It has a very slight hint of blue, and matches best with most LEDs. 8000K is our highest temperature, which produces an ice blue color. This is not a strong blue color though- it is still primarily white, meaning there will be no decrease in light output.
Relay:
Your Premium CAN-BUS HID Kit includes a brand new Heavy-Duty HID Relay, to power your HIDs directly from the battery, instead of the factory wiring. This relay has been designed from scratch, and utilizes a fully-sealed, waterproof relay, with flyback diode, and even has a built-in capacitor for input power smoothing. All wires are sleeved with braided techflex for an attractive appearance and extra protection. The input wires are each a meter long, and the output wires are one meter and two meters, which means the wiring will be long enough for even the biggest vehicles. The single-ground design makes installation easy. This relay was designed with reliability, convenience, and long-life in mind.
Warranty: Our warranty is through Diode Dynamics, LLC, so you can be assured that you will get fast and friendly service should you have any problems. There is a full-replacement 1-year warranty on all HID Kit components, including HID Bulbs, Ballasts and Relay.
Shipment: We carry our own inventory, so no waiting for them to be shipped from overseas, or waiting on big, unreliable suppliers to ship them. They ship right from our own inventory, in St. Louis, Missouri, usually the same day you order.
  • One pair HID bulbs in your choice of bulb size and color
  • Two 35w super-slim ballasts
  • Mounting hardware for ballasts
  • Three-year limited warranty on all components
  • Free Diode Dynamics decal
  • Diode Dynamics 30-day satisfaction guarantee
  • OPTIONAL* Heavy-duty HID Relay Harness to protect your factory electronics.
CLICK HERE FOR TO SELECT YOUR HYUNDAI
We offer pre-drilled dust caps for the Hyundai Genesis Coupe low-beams
*PM us for the free-shipping code* (U.S. forum members only)
Questions? Feel free to post, PM, email [email protected] or call: (314) 205-3033
Thanks for looking!
Nick C.
Any close future plans to fit the new 2016 Tucson Limited Ultimate?
We are in the process of updating the site to include 2016 model years
If you are having trouble finding bulbs for your 2016 Tucson, please send an email to our customer service team: [email protected] and we will help you find bulb models to fit your Tucson.
Thanks!
Nick C.
Can you upload a picture against the wall of stock halogen and hid? I'm interested in knowing how the hid kit perform in stock projector, like how the cutoff line looks like. Thanks!
Here's another color comparison with our HID conversion kits installed:
The factory projectors do a fairly good job of focusing the output, but you'll want to retrofit new projectors to reduce glare.
Nick C.
Any sort of deals or coupon codes for Canadian members?
Also, do all of you ballasts now include a can-bus module? I'm looking at getting a kit for my SUV (non-Hyundai) and need to make sure it will work. You have it on the site and I'm almost ready to order - just need to confirm about the canbus module question... :)
Discussion Starter #8
We have authorized dealers in Canada, check out our dealer map: Dealer Locator
Our HID conversion kit works best with the relay harnesses installed
I suggest giving us a call if you need more information: (314) 205-3033
Thank you!
Nick C.
Do you have them for the 2016 Tucson? They seems to have a unique H7 bulb holder.
Discussion Starter #10
We do offer an H7 bulb holder, which works perfectly for most KDM-market vehicles.
Feel free to contact us if you would like more information: [email protected]
Thank you!
Nick C.
Discussion Starter #11
Do these kits come with the auto levelers so you don't blind oncoming drivers?
Our HID conversion kits replace your existing halogen bulbs. If your vehicle is equipped from the factory with auto levelers, they will provide the same function with HID lighting.
HID conversion kits work quite well in projector style housings
Nick C.
Hello!
Do the 2017 Sonata's without HID's need the canbus setup? Also, do you sell the pre-drilled dust covers separately, And do they work on the Sonata? They look like they match.
Discussion Starter #13
Hello!
You will need an HID relay harness in addition to the HID conversion kit. The dust cap covers were designed specifically for the Genesis Coupe and have not been confirmed to fit on the Sonata.
Please feel free to give us a call if you have any additional questions: (314) 205-3033
Thank you!
Nick C.
Can you send me a quote for a 4300 or 6000k kit for the 2013 Santa Fe Sport?
Discussion Starter #15
Pricing starts at $150 per kit. We offer free-shipping for U.S. forum members, please send us a PM to receive the code.
Thanks!!
Nick C.
Could you send me a quote for low beam HID's?
1 - 18 of 18 Posts
