We just both a Hyundai Grace 2001 model. the problem is that the headlight is not producing enough so its hard for me to travel every night which i usually do. what suppose to be the solution and why is it not producing enough light?
if the headlight is working but not bright, first try a new bulb, if that does not work you have a bad connection, check the wiring terminals on the back of the bulb in particular the ground/earth connection
im currently in manila and far from my van., so i will ask someone to do those task for me, and post the result soon...
does anyone know hot to remove the entire optic from a Hyunda H1? Because I have a similar problem. The light from de headlight is not very clear and I think it´s because the front of the optic is not very clean, there is some dust inside of it and I would like to clean it from inside. thx!
