I have done the petrol filter change four times on my Getz now by myself.
And it getz easier every time.
You will have to lift you seat up and unclip the carpet to gain acces to the pannel.
Remove the top pannelwith a socket and ratchet of the correct size.
You will see that there is a black rubber muck that is the seal of the pannel to stop fumes ect to enter the cabin, just pull the pannel off an try not to lose any of the sealant as it can be used again and again.
Now take out the filter with the float (fuel level) unit.
take everything apart , taking photographic memory like shots with your mind remembering where everything fitted. (not as hard as it sounds)
now you will have to put in all the o-rings into the new filter that you took out from the old one. (it helps to put it in its place as you take it out of the old one)
Rebuild the float to the filter and pop it back in the tank.
close up the pannel and carpet and flip back you seat.
Hope it helps a little.
