I need help with my getz crdi. It will start when I spray brake cleaner but won't start without the brake cleaner. Any ideas what's causing the no start? Please help
When you start it using brake cleaner, is it able to keep running on it's own when you stop spraying?
It runs normal after I spray brake cleaner. The other problem with it is that, there's no power on the dlc plug, so I can't read any dtc codes.
Sounds like there is a fuel pressure issue in that case. The engine driven pump isn't able to build enough pressure to get the injectors firing at cranking speed. But when it starts on the brake cleaner the engine turns faster allowing the engine driven pump to generate more pressure. The most common cause of this problem is a fuel leak, more often than not via a faulty injector.
Try replacing the fuse in the yellow carrier on the dashboard fusebox.
BTW, why did you start a thread relating to a Getz on the Elantra forum?
