Good morning, need assist my Hyundai gets 2004 ,it giving me a problem wen l drive it long distance it jus stop and l have to wait to be cooling down so that l can start it again or for me to drive it .l did servive, change clutch kit but still is doing the same .
You might want to repost this in the Getz forum rather than the Accent forum.
Why was the clutch replaced? Do you actually loose drive due to clutch slip or does the engine not want to start?
If the engine doesn't start when hot, check the crank position sensor.
If you loose drive when hot due to clutch slipping, bleed the clutch and check the free-play and the pedal.
