Hi Guys,
I've been experiencing this issue for close to two years, made several unsuccessful trips to the dealership where the last thing they did before the warranty went was to swap with another Elantra from their rental division. The problem is like this (hope I can explain it sensibly; be warned, it will be a bit long-winded):
- My initial reported issue was that the steering felt looser than it usually would. The service manager at the dealership tried many times to sell me that it's just how Hyundai's steering feels, but I've been the one driving the car all the time, so I know when the feeling started to change. I also compared it to a rental they gave me to use (same year/model) and it felt nothing like mine did. Over time, the problem worsened to the point where it became unsafe to drive the vehicle, and I returned it to the dealership and left it there, demanding that they resolve the problem. They kept it for close to a month and gave me another rental to use (Nissan Sentra) while they did 'testing', which involved the service manager driving it daily, and having other employees driving it as well. In the end, he said they found no problems, and they adjusted nothing. When I took it back however, the problem was still there. This is when after much haggling, they decided to swap the steering assembly which was at the end of my warranty. So essentially they washed their hands.
That's the back story. Fast forward to today, while driving, I had cause to overtake a slow driver and when I turned the steering to the right to begin to overtake, while doing said overtaking, the steering literally locked to the right instead of re-centering as it normally would, so I had to now manually turn it myself. The steering also feels wobbly and gives a sort of feeling like the car is dancing on the road. My tyres are brand new (GoodYear Direction Sport at the front bought last Thursday, Nexen CP56s bought early June) and balanced as when I got the GoodYears, at 90 the steering began to vibrate, so that's no longer happening. The car was aligned to spec (or so I thought), but today I also noticed that if I release the steering, it begins to pull to the left. I also have a bit of excessive vibrating when the car is in park or reverse. Finally, when parked, if I move the steering left to right and vice versa, I hear a slight knocking sound as it goes past I would say 15-20 degrees either side (I'm not sure if this noise is normal as I can't recall having heard it before). I've placed the car up for sale, but being the type of person I am, I would prefer to give the new owner with as minimal or no problems as far as possible, while still letting them know that x, y or z is still happening. I apologize for the long-winded post, but just trying to lay as much info out there so that I can get all your opinions on what may possibly be the cause. The new mechanic has been really helpful and unlike everyone else, has been listening and actually working with me to fix the issues (dealership made me feel like I was an idiot), so if you guys have any ideas, please let me know. If there's any additional info needed, I'll do my best to answer.
Thanks in advance.
- I went to a mechanic I knew from my Nissan days who had experience with these vehicles as he used to work at one of our island's dealerships that are responsible for Kia, Mazda, Audi, etc. His first check showed that the stabilizer links were shot, but he failed to change the bushings on the bar (more on that later), so those links eventually went bad as well. Changed the ball joints which were also shot, top engine mount which was shaking (dealership refused to change it when I made them aware of the same) and strut mounts. Replacing these parts made a bunch of noises from the front end go away, so it was a good, but the steering issue eventually returned. He also scanned the car (not sure what type of scanner he had) and found no issues. I eventually took the car to my current mechanic as when I took it to this new guy initially, they checked and found a racheting spanner in my engine filter box.. from the previous mechanic. Plus the guys that old mechanic had working with him, loosened my brake line which I had to end up fixing with my cousin by bleeding the line of air and then re-filling with fluid. I didn't realize the line was loose until I was dropping my gf home and had to do the flintstones bit to get the car to stop on my way back.
- New mechanic found and resolved a whole host of problems including a knocking/rattling sound that the steering made, replaced the stabilizer links again as the left side broke and the stabilizer bar bushings. that restored control and some stability to the car. Also replaced my spark plugs which were shot (dealership never replaced them even though they said they did at my 50K service) and gave the engine a full flush/servicing which was badly needed (dealership again).
Thanks in advance.
