1 - 1 of 1 Posts
I have been having a starting problem. The car starts great first turn of the key for days on end then for no reason it won't start. The engine turns over ok but it won't fire. We have had it towed twice to the garage but they could not find any code faults plus when the mechanic turned the key it started first time for them. It seems that when it won't start if you wait 10 to 20 minutes it starts as if there has never been a problem. So far I have changed the plugs, plug wires, both ignition coils, the relay, battery, I also changed the fuel pump and filter on October 31st but it still happens again tonight. (4 days after changing everything) But it started on the 4th attempt after waiting 15 minutes. When the car is running it runs great, no missing or sluggishness and every day travels 100km back and forth to work at 120km/hr on the highway. I dropped it off at the dealer tonight because I am at my wits end. Can anyone suggest a possible cause? Thanks. Viv16
1 - 1 of 1 Posts
