Hello everyone,
I am the owner of a new 2022 Hyundai Accent SE.
Overall, the car has been great. I do have one small issue - occasionally, both the trunk light and the TPMS low-pressure indicator light turn on. This has happened five times, each of which occured after spending time in heavy traffic going very slowly. In addition, when I tried opening the trunk after arriving, the key fob was unable to open the trunk, but the manual lever in the cabin worked.
I have verified that the trunk was closed and the tire pressure was correct. Originally it was 31-32 psi, so I raised it to 36 psi because of cold weather. The issue persisted, so I brought it to the dealer. They were unable to diagnose anything due to the intermittent nature of the issue, but I do have it documented.
Another thread by a 2022 owner was not resolved and a similar thread by an owner of an older car with a similar issue resulted in speculation of a bad ground. Is there anything else that I can practically do? I'd rather not work on it myself, but if all it is is a bad ground strap in an obvious location then I may be able to tighten it.
Thank you.
Thank you.
