1 - 12 of 12 Posts
Help please I can't seem to find the exact color wiring diagram , and when I try to register HMASERVICE.com the terms and agree link is broken , please I been 3 months without a radio ! :confused: :(
thank you so much !!! I dont know why it wont let me sign up on the site , going to see if it works now
ok one more quick question
how do I Read that diagram like this for example
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/White
Car Radio Constant 12v+ Wire: Red:: This would be the Or/Blk from the Room Lamp Fuse.
Car Radio Switched 12v+ Wire: White/Green:: This would be the Gry/Wh from the Audio Fuse.
Car Radio Ground Wire: Black:: This can be bolted to any grounded part of the dash metal.
Is this what you needed?
Jim
Discussion Starter #7
appreciate the reply's , im trying to connect my pioneer unit and its asking to me to connect the orange wire " Lighting Switch Terminal " , does the hyundai diagram name it something different ?
Or/Wh is for the dial/faceplate illumination at night.
Usually, this is fed from the rheostat on the Headlight switch (actually on the dash).
This may be difficult to do on the Accent.\
If you don't mind it being at full brightness (no rheostat control), connect the Or/Wh to the thin Grn/Wh wire going to the speedo/gauge cluster. This wire should go live when either Park or Headlights are On.
Jim
1 - 12 of 12 Posts
