So my 2012 Sonata is refusing the change the vent directions. Its stuck on the main vents and partially the feet. I just replaced the mode door actuator on the driver side and they still won't change. I can hear it trying to change the direction but it doesn't. What could be the problem?
Is the actuator rotating when commanded? If so, It's not connected to the door or the stub it turns is broken.
It is rotating when the command is sent. I thought I connected it all up right (the 3 little stubs) and I see the stubs rotating (well just 1 because of the angle I was at). How would I go about getting those fixed and or replaced?
You'll have to pull it out and fix or replace the door.
