Is there a typical location for how to guides or walk thrus? I'm looking for '07 (with 2.7L) Radiator replacement guide. I saw a couple thread discussing, but no "here's how you do it"...
TIA
Pretty simple, remove several bolts, unplug the fan and pipes. You can remove the fan first to have more room. If you have difficulty removing the pipes, just cut them with knife and get new ones at autozone
I saw someone talking about needing to remove the front bumper? Additionally, I don't think I have tow package and cannot see any additional pipes/hoses off the radiator, they would be visible from above (without having to take the rad out) correct?
Have a look at this document, full engine teardown, scroll to the section of the document for the coolant system (starts at page 61).
https://www.slideshare.net/bobbyg9/27-l-engine
That guys has shared basically every manual related to this generation of Santa Fe. Very helpful!
https://www.slideshare.net/bobbyg9?...king&utm_medium=sssite&utm_source=ssslideview
Well I ordered a Haynes, but it's not the same quality of some Haynes manuals I've owned in the past. That said - using about 3-4 different uploads from bobbyg from your site/links, I was able to get things pulled apart! So thank you so much for directing me there.
