21 - 35 of 35 Posts
Don't know why Hyundai didn't save money and just have all horn functions just routed through the main horns anyway! Seems silly to have a separate (and weaker) alarm horn.
Does anyone know how to do this on a Sonata? The relays are a little different, and I'd like to make sure I put the wires in the right spots.
You should be able to do the same thing if you look at the fuse box diagram to see the corresponding plugs you need to use.
Yeah... my eyes were messing with me. I was thrown off because of the different orientation of the relay. The pattern looked different, but it's the same.
I was about to do this on my 2011, but then I noticed, there was no horn next to the passenger side strut tower?? So I'm guessing everything already routes through the front horns. Still the horn and lock beep sound different??
Fantastic mod! Thanks for sharing. My car sounds so manly now!
Does anyone have the original picture showing where to place this jumper? It has been so long that photo has been deleted. I too, would like to sound horns instead of wimpy electronic beep. Thanks.
Here ya go. Now I made this mod years ago and I did not want to pull/dislodge the relays, but you can see where they are connected. The "B/A Horn" bottom left is connected to "Horn" top left. Hope that helps.....
443944
443945
Thank you so much Woketman! I didn't think I'd get a response since it had been over 5 years since last post on this issue.
Now, does your horn continually blast now when you exit the car with the engine running? My beeper makes a long tone when you exit the vehicle and the key is in your pocket. Would kinda suck if your coming home late, and get put to open the garage door, and your horn is blasting through the “hood!
Mine does not. However I DO NOT have the key less system on my 2012. I insert a key and turn it to start, no start button.
21 - 35 of 35 Posts
