there are orange reflectors on my 2004 accent that are located towards the rear of the side panels, sort of above the wheels. how do i replace a burned out bulb?? does one have to remove the black plastic liners in the trunk area, or can the reflector lens be pulled off for access??
I have a 2000 Hyundai accent and just had to do this myself. The 2004 might be a little different, but it should be pretty similar. The sidemarkers should have two screws on them, so just unscrew those. If they've never been removed, the plastic shield might just be stuck on a little bit from dirt/sand/salt etc. Just wiggle it off, should be no problem. Once it pulls out, you'll see the wires and bulb harness. The bulb harness twists out of the sidemarker itself, then just remove the bulb and put the new one back and put it back together inverse of how you took it off.
I believe the sidemarker bulbs are 168 but they may be 194; check at your wal-mart or autozone.
