1 - 1 of 1 Posts
hi guys i've got a 2.7 V6 on my santa fe and im doing the timing belt kit job. got stuck a bit.
it was leaking oil bad from crankshaft front seal. seal was so old and bad it just chipped to tiny pieces and i couldnt get it all out. lip is still in there.
so i was thinking i have to get the oil pump out to get it all cleaned? i removed lower oil pan and undid 4 screws that seemed to fix to oil pump. also undid the bolts in front of oil pump. its still not moving.
is it just because of sealant or did i miss some bolts or anything else? how to get it off? and would that make possible to clean the surface from old melted seal?
thanks guys
martin
1 - 1 of 1 Posts
