61 - 64 of 64 Posts
2013 Hyundai Santa Fe Sport 2.0t limited
You can see in the video him doing just that, he use only the 3/8 ratchet with nothing on it to remove it so you can do the same to install it.
Forget what I said and do not use a screw driver or plier since you already broke the wing that way. Use the 3/8 ratchet.
I would highly recommend replacing it, with one wing missing he could maybe pop out of the hole with vibration and time.
448692
Incidentally, how is reset done after drain n fill. The shows “next” (inverted triangle” and reset.
Appreciate it
Discussion Starter #64
You're welcome! Glad to help. Sold the car last year and replaced it with a Palisade.
61 - 64 of 64 Posts
