1 - 8 of 8 Posts
I've been seeing some oil leaking out at the valve cover bolts... Nothing serious but i figured I should at least try and research how to fix it myslf since its probably as simple as taking the bolts off and pulling the old gaskets out and dropping new ones on it.
Anyone have an instruction guide or manual or schematic for me? Also, Torque specs of the bolts on the covers?
Adam
QUOTE (AmongthechosenX @ Aug 4 2010, 01:50 AM) index.php?act=findpost&pid=347004
Adam
Have a look through this thread, you'll find a post by me where I uploaded the 1.6 engine section of a repair manual - that should show you what you need to know.
Have you tried just tightening the valve cover bolts evenly to see if that fixes the problem?
QUOTE (Alfons @ Aug 4 2010, 12:02 PM) index.php?act=findpost&pid=347083
car has 140k miles, so i would doubt that its simply "loose"... new gaskets are less than $15, and if I can do it myself in 2 hours, then why not? lol
PS: THANK YOU For that manual. Thats all I needed! it shows the bolts holding it and the torque specs for reinstalling the bolts.
Cover gasket is baked almost hard as rock, not pliable anymore,
Get a new cover gasket, (4) spark plug tube seals, some RTV, and run with it.
USE A TORQUE WRENCH when securing cover bolts to cylinder head... the cover is plastic ....
QUOTE (sbr711 @ Aug 4 2010, 03:42 PM) index.php?act=findpost&pid=347139
can i get all of that at a local auto parts store? I don't know what tube seals look like and i have no idea wtf RTV is haha
QUOTE (AmongthechosenX @ Aug 4 2010, 04:44 PM) index.php?act=findpost&pid=347166
Yes, though not an everday sale for them, they may have to order... we keep it all on the shelf at our place.
I don't know what tube seals look like and i have no idea wtf RTV is (silicone goo)
I used a Felpro gasket set from Advance Auto. It had all the parts you will need. And instructions. You shouldn't need RTV unless your cover is warped.
1 - 8 of 8 Posts
