Hi there, just joined the forum yesterday. Got this Getz 1.1L 2008 model this year from a friend with 45K mileage. I took it for a motor oil change last week, the mechanic saw the PSF is at 'low' and asked me to get the same fluid type (PSF-3) to fill-in. Check online for PSF-3, seems its already out of the market.
Does anyone refilled their PSF with another type compatible with PSF-3 without any problem?
Thanks in advance.
Thanks in advance.
You'll be fine with any equivalent fluid.
00000732
Thanks,
Welcome aboard.
I went to some Prestone PS fluid from WalMart a year ago on my Accent. $4 a quart. I would drain all the old out before adding the new.
You'll be fine with any equivalent fluid. Don't worry about draining it. Just top it off.
