1 - 8 of 8 Posts
I replaced the first COP (coil on plug) at 104 K miles.
Because the check engine light did not come on and throw a code, I had to swap cops across the
different cylinders until I found the bad one. The engine miss did not occur when the engine was cold,
I hade to drive the vehicle for a least 45 min. to get the cop hot enough to cause it to fail.
The replaced the second COP (coil on plug) at 107 K miles.
This time the check engine light came on and it threw a code, so I knew what cylinder had
the bad cop. Again the vehicle ran fine when cold, but after 45 min. driving is when it would
break down from the heat.
The COPs are replace on fail, not a maintenance item. I have seen them fail as early as 50K, but have seen them go 80K plus and still working just fine. Surprised you didn't get a code on the first one. Never seen that before.
It was a 2010 I have a 2016 sonata sport now
I had a Hyundai Sonata with 190 thousand miles I had the original spark plugs and timing belt
You were on borrowed time........
2019 Elantra GT N Line, 2013 Hyundai Elantra GT (SOLD)
I had a failed Coil Pack at around 42-44k miles
132,000 kms (82,500 miles) all original on 2013 GT.
I did have to replace a crank position sensor under warranty... at 30K kms.
Not a GT but mine are original and so are the sparks. I have heard that the 1st transistor made by TI is still oscillating.
1 - 8 of 8 Posts
