Hi folks, not sure if this has been discussed already, but what is the total amount of gas that the VZ can hold. I normally fill up my tank when the gas light comes on. The fuel gage indicator normally shows I have about 70 - 80 km in gas range left. The manual says in CAD 78 liter capacity / US 20 gallons. I can only put in approx 65 - 67 liters when i fill up before the gas pump clicks to full. Does the VC have a big reserve tank hence why I can only fill that much gas. I am avg 12 liters /100km. I can probably do a little better if I slow down :)
Yes it's been discussed a LOT.....about various models.
It is the new "normal" to get early warnings of running out of gas.
This is partly because many fuel pumps are cooled by the fuel and damage can occur if you run completely OUT.
Also fuel injection systems are sometimes hard to prime again if they get full of air.
