My dealer is offering me 10K intervals with their synthetic blend and it also gives you a lifetime warrenty on the motor if you keep it up and let them do it for $79.
I am coming up on my 2nd change (regular oil at 3K) at 8K and am concidering it?
My dealership in Alberta told me every 3-4000kms or 3-4 months,whichever came first..I was looking for a thread on this... there is another thread on DIY oil changes... but i'm looking for the solia answer on Synthetic oil changes - and the intervals of changing it.
I called my Hyundai Dealer on this, and wasn't happy with the answer. I haven't done an oil change yet, but i'm getting close. 6000km is supposed to be my first change, i'm at 4700 now.
I called the dealer and mentioned I want to use synthetic oil, and asked what the intervals woult be, he said 6000km. I said that 6000km was supposed to be for regular oil, but what would the intervals be for synthetic?
He said "the same - due to the turbo is harder on the oil, so they keep it at 6000km intervals".
I didin't believe that... yet, there is no specific info that I can find in the user manual/maintenace log book.
Anyone?
Well it's a good question - I'm not sure how many if any auto makers specify longer change intervals if you use synthetic vs fossil . Most have different intervals depending on type of service and a number of turbo charged engines and high performance engines require synthetic meeting certain ratings.I was looking for a thread on this... there is another thread on DIY oil changes... but i'm looking for the solia answer on Synthetic oil changes - and the intervals of changing it.
Anyone?
detech, is one of those two chains a timing chain?Besides the turbo you have 2 chains in the engine as well which are protected from wear better with syn. And I think the engine uses low friction piston rings which tend to make for dirtier oil .
yeah - a timing chain and there is a balance shaft which is chain driven. Both should last a very long time - however on my Saabs I've never replaced a turbo charger but have had to replace timing chains on two of them - one was owing to a defective chain tensioner.detech, is one of those two chains a timing chain?uzzled:
All modern engines built or sold in Europe effectively need full synthetic - as the only current ACEA approval sequences all include a requirement for "stable, stay-in-grade oil" it's unlikely that a part-synthetic or mineral oil could meet that requirement but these are still on sale for older engines.I read somewhere that some Mercedes engines require a synthetic oil that meets a spec which is meant to ensure proper lubrication of the timing chain.
See, my point exactly! What is it with every single dealership having different stories on the amount we go between oil changes?!My dealership in Alberta told me every 3-4000kms or 3-4 months,whichever came first..
Because I have a turbo engine I should get it done 3-4x a year because of the heat in the engine
BUT....
They also use 5w 30 so I'm not sure how that affects my intervals...
That really is customer support at the lowest possible level !!Ok, so I called Hyundai Canada directly, and spoke to a rep there. He pulled out the owners manual along with me, and he confirmed what the manual says.
How he put it was that since Hyundai does not test their vehicles with Synthetic Oil, they do not extend the amount of KM's between oil changes over conventional oil.
Since the manual says every 6,000 km (see your service manual, not owners manual), that's when the oil change has to happen - regardless if you're using Oil or Syn.
He said once you're past the warranty period, you can really do what you feel is required, but if a warranty issue ever came up that had to do with oil, then the specifics would have to have been followed.
Funny, it's 3-4000 miles or 3-4 months here in the US. lol. don't listen to your dealer.My dealership in Alberta told me every 3-4000kms or 3-4 months,whichever came first..
BUT....
