I need help. I'm attempting to do the bps short shifter install.
How do I remove this panel with the USB port and 12v port? Step 6 in the image.
Do I just use a pry tool and I force it between and pull? I see there's a small gap at the top which may have enough space.
Use a screwdriver or trim removal tool and pry the panel off.
If you look at the image at step 7 you can see the two clips near the top of the panel that hold it on.
Thanks. I figured it out. I used a pry tool and jammed it right in the middle of the sides... that is were the clip is located.
BTW, the shoft shifter is great. Reminds me of back in the day when I still had my Civic Si with a short shifter.
I'm also having a hard time with this panel. It seems to have gaps everywhere but the top, and the surrounding console makes it hard.
