Dear All:
A HOLD light has just appeared on the upper right hand corner of my dash.
The car is OK to drive, but a bit of web searching tells me that this indicates the car gears are locked in a certain configuration - and in retrospect the car did feel a bit "heavy.'
Any advice on how to turn off or release the HOLD?
Thanks in advance for any responses -
Andrew Salmon
Seoul
Steady light - read the manual to find the button that disengage the HOLD:
"Select the "HOLD" mode when starting your vehicle on a road surface slippery from snow or the like, and the vehicle will start smoothly. If you start your vehicle with the selector lever in other than the "L" position, the vehicle starts in second gear."
If is flashing - probably needs transmission service.
Dear All:
Andrew Salmon
Seoul
