1 - 20 of 20 Posts
Wait why did you have to replace motor?
I have the AWD limited (2nd owner - bought at 103k) 2.4l
Now have 126k
Yes, that is correct. I am currently at 188k miles (majority are freeway miles). Engine failed from rod bearing failure at 145k - apparently there is a lawsuit in place due to a bad manufacturing design on these 2.4 theta II motors. I tried to get A warranty replacement since my vehicle was part of the recalled cars with extended warranty up to 115k. However, since I Was 30k over they said No. I replaced it with a used 60k motor that was pulled from a wrecked Tucson by my mechanic. My commute is 49 miles each way so I plan to keep the car to see how much the engine goes for this time (currently at 100k+).
At 124,000 on our 2014 limited..
183k miles on 2012 limited
But noticed my tire pressure sensor flashing last night then stay on, go off and start flashing again. I know they go bad over time.
And need to change brakes and rotors again - have warped rotors again - very annoying
And I think tires are bad - even though they have tread life left they're making a lot of noise
Sent from my Pixel 6 using Tapatalk
Have 192335 on my 2012 Limited AWD
Just changed the earl. Full synthetic
Got new tires in September
Big $ but worth it as old tires were noisy as Fcuk.
New shoes are Goodyear Assurance Maxlife. Quiet and smooth
Just hit, 130,000 tonight on our 2014 limited. Going to replace both blend door actuators as there acting up on me as of late.
thanks
pat
1 - 20 of 20 Posts
