Hey everybody I think my highbeams are alligned incorrectly, they are bright however they seem to be adjusted inward.. I'm posting to see if this is the standard or do mine need to be adjusted? Here are some photos
Low Beam (My driveway is on a slight slant)
High Beam (See how the hot spots are focused inward?)
Aiming headlights...
Dj, Owners manual has a detailed description of adjustment procedure. In my manual (2009 GLS) Section 6 Page 27. Yours should be close to that I would imagine. I hope this helps and good luck!
I love the "Self-help Sections" of the manuals. Just enough to get you into real trouble if you are not mechanically inclined. ;)
I haven't looked at my manual but can you actually adjust each beam? I believe the assembly is adjusted as a unit. I would think the high beams are for seeing down the road hence the inward casting.
BTW when the high beams are turned on the low beams stay on for side vision and the highs come on for far forward vision. That's what you are seeing.
