Shouldn't be any problems with it, though I haven't changed them on mine yet. I did however change the H7 bulbs in my Tiburon in favor of a HID kit with zero issues.
As for size, you should be looking for a Hi/Lo H4 kit (same as 9003). I'm probably going to be purchasing a set for myself in the next couple of weeks. I'll be sure to post a tutorial on it when I finally get around to it.
I converted to HID lighting for my low beams and fog lights. You must add a relay to the ballast for the low beam and one for the fog lights. The ballasts draw too much current.
QUOTE (Joeeey @ May 4 2010, 02:55 AM) index.php?act=findpost&pid=319339
Depends on what HID kit you go with... The digital ballasts barely draw more current on startup than the standard 55w halogen bulbs do while running. That being said, I would still use a relay in any aftermarket setup simply to isolate it from the rest of the system.
