i have searched with little results
where is a good place to mount hid ballasts for the fog lights?
I'm looking to do a clean install and hide as much as possible (within reason)
i have older large ballasts so i cants use adhesive
I have mounting brackets so i need a bolt or drill access
I will not stack them on my other ones (saw that some people do)
I'm running out of room and ideas ... please help
pics are appreciated
here is my current install locations
drivers side (+relay):
passenger side :
Relay harness:
Discussion Starter · #2 ·
bump
2013 Sonata SE
i took my bumper off when doing all my front hid lighting. ballasts are mounted together and they are mounted behing the actual bumper
nice!
did you use an existing bolt or just drill a new one?
2013 Sonata SE
nice!
i used 2 zinc self tapping screws a little under a 1/4" long on the hid ballast bracket. they have been fine ever since. i like having stuff hidden. if anything ever goes bad, it's not a problem for me because it only takes me 5 minutes to pull this bumper. easiest bumper i have ever pulled off all the cars i have worked on!
