Long detailed story................
I had a local shop install the HID kit almost 2 years ago (Bada Bling! kit). I have 35w ballasts on both lows & fogs with relay harnesses on both (No issues at all until now). I recently decided to change my low beam bulbs to 5000k from 4300k just for color change about 2-3 months ago. After about two weeks I noticed the passenger side was having issues with not turning on maybe 1-2 times per month. I would just let it cool down for 10-30 minutes and then they would work fine. I assumed it was a bad bulb because I wasn't having issues until the bulb change. The shop asked me to swap the ballasts or bulbs to determine the issue. I chose to swap the ballasts as they were easier to swap. This is when I started to notice that the passenger side seemed to be slightly dimmer than the driver side. I swapped the ballasts again but the slightly dimmer side remained on the passenger side. I took the car to the shop and they went ahead and warranteed the bulbs but the issue stayed the same (slightly dim on passenger side). I decided to start learning about HID online so I could do the work myself. I purchased a set of higher quality bulbs online (great 5000k color & metal base) and installed myself but now the problem switched sides so the passenger side seems to be brighter than the driver side now. I swapped the ballasts again but no change. What could be the issue? Is there a ground, connection or fuse that I should look for that could be causing this? Could the ballasts being almost 2 years old be causing the slightly dim side to switch when bulbs are changed? Everything was fine until I started switching bulbs. I also double checked to make sure the bulbs are seated properly so that's not the issue.
