1 - 13 of 13 Posts
Hi ,i Replaced underhood battery due to my car not starting
& now stereo / radio /Cd player dosnt work WTD?
i have tried reading owners manual but not much info there
& have my MP3-01 Security Card code 4383 to enter,
but i dont know procedure to do it
can anyone help please ? thankyou
not totally certain but on wife's Getz, code was entered by channel buttons eg, press 4 times on 1st button, press 3 times on 2nd button etc etc... might work or might not, good luck.
hi, yes i tried last night & B4,, the numbers stay there 4383 then ,,,,nothing else seems to happen
i tried other buttons after 4383 is pumped in to switch it on,,
nothing happens
Discussion Starter #8 (Edited)
problem is dealership is over an hour away in off-peak traffic
on screen it shows icde 8800,,
then when i go buttons seq,, it will show icde 4383
i had a look for search scan , trackup & down buttons ..
pressed them for prolonged times ,,still nothing happens
not totally certain but on wife's Getz, code was entered by channel buttons eg, press 4 times on 1st button, press 3 times on 2nd button etc etc... might work or might not, good luck.[/QU
as per instruction manual:
check that pin code shown on screen is "4383"
press pre-set button (5) once to activate pin code.
or, as Easy Rider said, call a dealer
Discussion Starter #12
iana ,i thank you very much, it is as you have said,
the # 5 button & radio came on instantly ,,cheers
1 - 13 of 13 Posts
